Sculpted for your hand and designed for an elegantly simple work space, mouse is the perfect partner to your device. It was designed to match the sleek aesthetic and exceptional performance. The metal scroll wheel feels solid under your finger, and the shape of the body fits perfectly in your hand. Mouse is designed to have premium precision pointing and clicking for scalable performance across the screen of your device and external monitors. With precision-tuned sound for clicks and scrolling, mouse is quiet enough to not be heard while quickly responding to your touch.
                Complements your SurfaceSculpted for your hand and designed for an elegantly simple work space, Mouse is the perfect partner to your docked Surface and Keyboard. It was designed to match the sleek aesthetic and exceptional performance of your Surface. The metal scroll wheel feels solid under your finger, and the shape of the body fits perfectly in your hand.
                Exceptional accuracyMouse is designed to have premium precision pointing and clicking for scalable performance across the screen of your Surface and external monitors.
                Carefully crafted experienceWith precision-tuned sound for clicks and scrolling, Mouse is quiet enough to not be heard while quickly responding to your touch.
- Microsoft Surface Mouse - mouse - Bluetooth 4.0 - grey
- Mouse
- Connectivity Technology
- Wireless - Bluetooth 4.0
- Grey
- Orientation
- Right and left-handed
- 6.416 cm x 11.516 cm x 3.376 cm
- 90.9 g
- Movement Detection Technology
- Optical
- Performance
- 1000 points per inch, 30 inches per second, 4000 frames per second
- Scrolling wheel, Microsoft BlueTrack Technology
- Battery
- AAA type
- OS Required
- Windows 8, Windows 8.1, Microsoft Windows RT 8.1, Microsoft Windows RT 8, Windows 10, Apple OS X 10.10 Yosemite or later, Android 4.4.2 (KitKat) or later, Apple MacOS X 10.10.5 or later
- Pricing Type
- Commercial
- 1-year warranty
- Mouse
- Orientation
- 6.416 cm
- 11.516 cm
- 3.376 cm
- 90.9 g
- Grey
Input Device
- Wireless
- Interface
- Bluetooth 4.0
- Max Operating Distance
- Up to 15 m
- Optical
- Performance
- Included Accessories
- 2 AAA batteries
- Pricing Type
- Commercial
- AAA type
- Technology
- Alkaline
- Run Time (Up To)
- 12 months
- OS Required
- Limited warranty - 1 year
