Make the most of every day with the sleek style, performance, and all-day battery life you need in the Surface Laptop, all at an exceptional value.
Key Features:
Keeps up with you all-day with up to 13 hours battery life*
Easy to carry—starting at 2.45 lbs. and just 15.69 mm thin
Run your favourite apps with a 10th Gen Intel® Core™ i5 processor
Show your best side on video calls with the built-in 720p HD camera
Type in comfort anywhere — full-size keyboard with large, precision trackpad
Our lightest Surface Laptop - Get the style, performance, and all-day battery life you need, all at an exceptional value.
Sleek design and standout value - The lightest Surface Laptop features our signature 3:2 aspect ratio that helps you see and do more, all on a 12.4" PixelSense™ touchscreen and in premium materials.
Familiar features and trusted Windows Hello security - One Touch sign-in with the Fingerprint Power Button on select models, all-day typing comfort on the full-size keyboard, and immersive Omnisonic sound, backed by Dolby® Audio.
Play, and code, deliver crisp, high-quality presentations, kick back with a movie night, or transform ideas into stunning visual stories on Surface Laptop Go.
*Battery life Surface Laptop Go: Up to 13 hours of battery life based on typical Surface device usage. Testing conducted by Microsoft in September 2020 using preproduction software and preproduction Surface Laptop Go 10th Gen Intel® Core™ i5 processor, 128GB, 8 GB RAM Microsoft Surface® Edition devices. Testing consisted of full battery discharge with a mixture of active use and modern standby. The active use portion consists of (1) a web browsing test accessing 8 popular websites over multiple open tabs, (2) a productivity test utilizing Microsoft Word, PowerPoint, Excel and Outlook, and (3) a portion of time with the device in use with idle applications.
Premium Surface design at an exceptional value
Ultra-light and portable, the apps, you use every day, premium materials, and a choice of must-have colors will make this your go-to laptop. -
The Surface Laptop features the signature 3:2 aspect ratio that helps you see and do more, all on a 12.4" PixelSense touchscreen, in premium materials and choice of colors. -
Learn, grow, create, and unwind
Play, and code, deliver crisp, high-quality presentations, kick back with a movie night, or transform ideas into stunning visual stories on Surface Laptop Go. -
Connect with the people who matter most
Meet, share experiences, and celebrate moments. Surface Laptop Go is perfect for video and conference calls using apps like Skype and Teams. -
Great for learning anywhere
With online education tools like Flipgrid, built-in HD webcams, and Studio Mics, school presentations are fun and interactive. -
Browse, play, and binge
Relax and shop in Edge, listen to music, podcasts and audio books, and stream your favorite Netflix, shows.
- Microsoft Surface Laptop Go - 12.4" - Intel Core i5 - 1035G1 - 4 GB RAM - 64 GB eMMC
- Product Type
- Notebook
- Operating System
- Win 10 Home in S mode
- Processor
- Intel Core i5 (10th Gen) - 1035G1 / 1 GHz, up to 3.6 GHz / 6 MB Cache
- Memory
- 4 GB LPDDR4X
- Storage
- 64 GB eMMC
- Display
- 12.4" touchscreen 1536 x 1024 - 148 ppi
- Graphics
- Intel UHD Graphics
- Input Device
- Trackpad
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax
- Battery
- Up to 13 hours
- Ambient light sensor
- Dockable
- Security
- Firmware Trusted Platform Module (TPM) Security Chip
- Platinum
- 27.818 cm x 20.567 cm x 1.569 cm
- 1.11 kg
- Limited warranty - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Home in S mode
Processor / Chipset
- CPU
- Intel Core i5 (10th Gen) 1035G1 / 1 GHz
- Max Turbo Speed
- 3.6 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Smart Cache
- RAM
- 4 GB
- Technology
- LPDDR4X SDRAM
Storage
- Main Storage
- 64 GB eMMC
Display
- 12.4"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1536 x 1024
- Widescreen
- Pixel Density (ppi)
- 148
- Image Aspect Ratio
- 3:2
- PixelSense
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Dolby Audio
Input
- Keyboard, trackpad
Communications
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0, IEEE 802.11ax
- Run Time
- Up to 13 hours
AC Adapter
- Output
- 39 Watt
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB-C , Headphone output , SurfaceConnect
Software
- Software Included
- Microsoft 365 Family (30 days trial)
- Platinum
- Case Material
- Aluminum, polycarbonate
- Integrated Options
- Dockable
- Security
- Included Accessories
- Power adapter
- 1.11 kg
Sustainability Information
- TCO Certified
