Slim and stylish. Make a powerful statement and get improved speed, performance and battery life. The Surface Laptop 3 fuels your ideas and reflects your style with a thin, light design.
More power to do what you want
Whether you're creating, catching up or chilling out, Surface Laptop 3 gives you more power, fast processors, greater multitasking performance and instant on. -
All-day battery life
Up long hours of battery life plus a standby that extends your battery when you're away. -
Faster, easier, more natural navigation
The interactive touchscreen is optimized with strengthened glass for worry-free daily use. -
Loud and clear
Be heard loud and clear whether in conference calls or using voice dictation with enhanced dual far-field mics.
- Microsoft Surface Laptop 3 - 15" - Intel Core i7 - 1065G7 - 16 GB RAM - 256 GB SSD - English
- Product Type
- Notebook
- Operating System
- Win 10 Pro
- Processor
- Intel Core i7 (10th Gen) - 1065G7 / 1.3 GHz, up to 3.9 GHz / 8 MB Cache
- Memory
- 16 GB DDR4
- Storage
- 256 GB SSD - NVMe
- Display
- 15" touchscreen 2496 x 1664 - 201 ppi
- Graphics
- Intel Iris Plus Graphics
- Input Device
- Trackpad
- Keyboard
- English
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac/ax
- Battery
- Up to 11.5 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Platinum
- 33.95 cm x 24.4 cm x 1.469 cm
- 1.542 kg
- Localisation
- Region: United Kingdom, Ireland
- Pricing Type
- Commercial
- Specific Absorption Rate (SAR)
- 0.251 W/kg (body)
- Limited warranty - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro
Processor / Chipset
- CPU
- Intel Core i7 (10th Gen) 1065G7 / 1.3 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- RAM
- 16 GB
- Technology
- DDR4 SDRAM
Storage
- Main Storage
- 256 GB SSD M.2 - NVM Express (NVMe)
Display
- 15"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2496 x 1664
- Widescreen
- Pixel Density (ppi)
- 201
- Image Aspect Ratio
- 3:2
- PixelSense
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- Windows Hello
- Sound
- Stereo speakers, two microphones
- Dolby Audio Premium
Input
- Keyboard, trackpad
- Keyboard Layout
- English
- Multi-gesture trackpad, metal palm rest
Communications
- Wireless
- Bluetooth 5.0, IEEE 802.11ax
- Run Time
- Up to 11.5 hours
Connections & Expansion
- Interfaces Details
- USB 3.0 , USB-C , Headphone output , SurfaceConnect
Software
- Software Included
- Microsoft 365 (30 days trial)
- Platinum
- Case Material
- Aluminum
- Integrated Options
- Dockable
- Security
- Included Accessories
- Power adapter
- SAR Value
- 0.251 W/kg (body)
- 0.251 W/kg (body)
- Localization
- Pricing Type
- Commercial
- 1.542 kg
Sustainability Information
- TCO Certified
