Turn your ultraportable Surface into a desktop PC and boost your productivity with Surface Dock.
Plug in the Surface Connect cable to charge your device and access external monitors, keyboard, mouse, and more. Find the perfect viewing angle, or position your device to take advantage of the robust pen capabilities.
With two high-definition video ports, a Gigabit Ethernet port, four high-speed USB 3.0 ports, and an audio output, you’ve got all the connections you need in a sleek, compact design.
Surface Dock uses Surface Connect technology which enables high-speed transfer of video, audio, and data over a single cable, keeping your desk clutter-free. It also has a Gigabit Ethernet port giving you a fast, reliable connection to your network.
Surface Dock is quick and easy to set up. Connect your peripherals to Surface Dock and then attach the magnetic Surface Connect cable to your device. It’s that easy.
2 Mini DisplayPorts 1 Gigabit Ethernet port 4 USB 3.0 ports 1 Audio out port Surface Connect cable External power supply
- Microsoft Surface Dock - docking station - 2 x Mini DP - GigE
- Product Type
- Docking station
- Video Interfaces
- 2 x Mini DP
- 13 cm x 6 cm x 3 cm
- 550 g
- Networking
- Gigabit Ethernet
- Power
- Power adapter
- Pricing Type
- Commercial
- 1-year warranty
- Designed For
- Surface Book, Book 2, Book with Performance Base, Go, Laptop, Laptop 2, Laptop 3, Laptop 5 for Business, Laptop Studio, Pro (Mid 2017), Pro 3, Pro 4, Pro 6, Pro 7, Pro 9 for Business, Pro X
- Product Type
- Docking station
- 13 cm
- 6 cm
- 3 cm
- 550 g
- Data Link Protocol
- 4 x SuperSpeed USB 3.0 , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x display / video - Mini DisplayPort , 1 x audio - line-out - mini-phone stereo 3.5 mm
- Cables Included
- 1 x data cable - integrated
- Security Slot Type
- Kensington security slot
- Pricing Type
- Commercial
- Power Device
- Power adapter
- Limited warranty - 1 year
- Designed For
- Microsoft Surface Book, Book 2, Book with Performance Base, Go, Laptop, Laptop 2, Laptop 3, Laptop 5 for Business, Laptop Studio, Pro (Mid 2017), Pro 3, Pro 4, Pro 6, Pro 7, Pro 9 for Business, Pro X
