Microsoft Surface Dock - Thunderbolt 4 - 3 x Thunderbolt - GigE, 2.5 GigE
Quicklinx: HGZZWS00 Mfr#: T8I-00005
£220.02 ex VAT
£264.02 inc VAT
Turn your ultraportable Surface into a desktop PC and boost your productivity with Surface Dock.
Plug in the Surface Connect cable to charge your device and access external monitors, keyboard, mouse, and more. Find the perfect viewing angle, or position your device to take advantage of the robust pen capabilities.
  • All the ports you need
    With two high-definition video ports, a Gigabit Ethernet port, four high-speed USB 3.0 ports, and an audio output, you've got all the connections you need in a sleek, compact design.
  • Lightning fast with minimalist design
    Surface Dock uses Surface Connect technology which enables high-speed transfer of video, audio and data over a single cable, keeping your desk clutter-free. It also has a Gigabit Ethernet port giving you a fast, reliable connection to your network.
  • Easy setup
    Surface Dock is quick and easy to set up. Connect your peripherals to Surface Dock and then attach the magnetic Surface Connect cable to your device. It's that easy.
Microsoft Surface Dock - docking station - Thunderbolt 4 - 3 x Thunderbolt - 1GbE, 2.5GbE
Docking station
Docking Interface
Thunderbolt 4
Video Interfaces
3 x Thunderbolt
15 cm x 7.5 cm x 2.13 cm
410 g
Gigabit Ethernet, 2.5 Gigabit Ethernet
Power adapter 165 Watt Power Provided
1-year warranty
Docking station
15 cm
7.5 cm
2.13 cm
410 g
Video
Max Resolution Details
4K - 60 Hz (Dual Display)
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
3 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x network - 2.5G Gigabit Ethernet - RJ-45 , 3 x USB-C / Thunderbolt 4 - 24 pin USB-C , 1 x audio - line-out - mini-phone stereo 3.5 mm
1 x USB-C cable - integrated
Security lock slot (cable lock sold separately), 96W power delivery
Security Slot Type
Kensington security slot
Power adapter
Power Provided
165 Watt
Limited warranty - 1 year
Brand: Microsoft
