Turn your ultraportable Surface into a desktop PC and boost your productivity with Surface Dock.
Plug in the Surface Connect cable to charge your device and access external monitors, keyboard, mouse, and more. Find the perfect viewing angle, or position your device to take advantage of the robust pen capabilities.
All the ports you need
With two high-definition video ports, a Gigabit Ethernet port, four high-speed USB 3.0 ports, and an audio output, you've got all the connections you need in a sleek, compact design. -
Lightning fast with minimalist design
Surface Dock uses Surface Connect technology which enables high-speed transfer of video, audio and data over a single cable, keeping your desk clutter-free. It also has a Gigabit Ethernet port giving you a fast, reliable connection to your network. -
Easy setup
Surface Dock is quick and easy to set up. Connect your peripherals to Surface Dock and then attach the magnetic Surface Connect cable to your device. It's that easy.
 - Microsoft Surface Dock - docking station - Thunderbolt 4 - 3 x Thunderbolt - 1GbE, 2.5GbE
- Product Type
 - Docking station
- Docking Interface
 - Thunderbolt 4
- Video Interfaces
 - 3 x Thunderbolt
 - 15 cm x 7.5 cm x 2.13 cm
 - 410 g
- Networking
 - Gigabit Ethernet, 2.5 Gigabit Ethernet
- Power
 - Power adapter 165 Watt Power Provided
 - 1-year warranty
- Product Type
 - Docking station
 - 15 cm
 - 7.5 cm
 - 2.13 cm
 - 410 g
Video
- Max Resolution Details
 - 4K - 60 Hz (Dual Display)
- Data Link Protocol
 - Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
 - 3 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x network - 2.5G Gigabit Ethernet - RJ-45 , 3 x USB-C / Thunderbolt 4 - 24 pin USB-C , 1 x audio - line-out - mini-phone stereo 3.5 mm
- Cables Included
 - 1 x USB-C cable - integrated
 - Security lock slot (cable lock sold separately), 96W power delivery
- Security Slot Type
 - Kensington security slot
- Power Device
 - Power adapter
- Power Provided
 - 165 Watt
 - Limited warranty - 1 year
