Microsoft Surface 3 Power Supply
Quicklinx: BJBNWS00 Mfr#: 4GY-00010
Charge your Surface 3 extra fast while you work with the 13-watt Power Supply. This slim cord and adapter reaches behind furniture and into other hard-to-reach outlets with no problem. And you can charge another device like your phone with the micro USB port located on the Power Supply.
Microsoft Surface 3 Power Supply - power adapter - 13 Watt
Power adapter - external
63 g
United Kingdom, Ireland
Power Capacity
13 Watt
Pricing Type
Commercial
5.7 cm x 3.7 cm x 2.8 cm
1-year warranty
Surface 3
Power Capacity
13 Watt
USB cable 1.5 m
Pricing Type
Commercial
Limited warranty - 1 year
5.7 cm
3.7 cm
2.8 cm
63 g
Microsoft Surface 3
