Looking for a portable mouse that helps you get things done? Sculpt Touch Mouse saves time in long documents and works virtually anywhere, with no cables or transceivers to connect. And it's designed to fit comfortably in either hand.
The four-way touch scrolling pad on the Sculpt Touch Mouse lets you breeze up and down, left and right, and through windows and documents with just the swipe of your finger. While you scroll, you'll feel the nice surprise of tactile feedback.
Navigate quickly and smoothly through screens and docs
The four-way touch strip on the Sculpt Touch Mouse lets you breeze up and down, left and right, and through windows and documents with just the swipe of your finger. -
Ready right away, with nothing to plug in or lose
The Sculpt Touch Mouse uses Bluetooth connectivity, which means you never need to worry about losing a transceiver or giving up a valuable USB slot. Just pair your mouse and start swiping.
- Microsoft Sculpt Touch Mouse - mouse - Bluetooth - storm grey
- Mouse
- Connectivity Technology
- Wireless - Bluetooth
- Storm grey
- Orientation
- Right and left-handed
- 6.5 cm x 9.55 cm x 3.3 cm
- 111 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Performance
- 8000 fps
- Programmable buttons, touch-sensitive scroll, Microsoft BlueTrack Technology
- Battery
- 2 x AAA type
- OS Required
- Microsoft Windows 7, Windows 8, Apple MacOS X 10.6 - 10.7
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Orientation
- 6.5 cm
- 9.55 cm
- 3.3 cm
- 111 g
- Storm grey
Input Device
- Wireless
- Interface
- Bluetooth
- Max Operating Distance
- Up to 10 m
- Optical
- Buttons Qty
- 3
- 1000 dpi
- Performance
- 8000 fps
- AAA type
- Technology
- Alkaline
- Installed Qty
- 2
- Run Time (Up To)
- 9 months
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
