Microsoft Sculpt Touch Mouse - optical - 3 buttons - wireless - Bluetooth - storm grey
Quicklinx: 8DN2WS00 Mfr#: 6PL-00001
Looking for a portable mouse that helps you get things done? Sculpt Touch Mouse saves time in long documents and works virtually anywhere, with no cables or transceivers to connect. And it's designed to fit comfortably in either hand.
The four-way touch scrolling pad on the Sculpt Touch Mouse lets you breeze up and down, left and right, and through windows and documents with just the swipe of your finger. While you scroll, you'll feel the nice surprise of tactile feedback.
  • Navigate quickly and smoothly through screens and docs
    The four-way touch strip on the Sculpt Touch Mouse lets you breeze up and down, left and right, and through windows and documents with just the swipe of your finger.
  • Ready right away, with nothing to plug in or lose
    The Sculpt Touch Mouse uses Bluetooth connectivity, which means you never need to worry about losing a transceiver or giving up a valuable USB slot. Just pair your mouse and start swiping.
Microsoft Sculpt Touch Mouse - mouse - Bluetooth - storm grey
Mouse
Wireless - Bluetooth
Storm grey
Orientation
Right and left-handed
6.5 cm x 9.55 cm x 3.3 cm
111 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
8000 fps
Programmable buttons, touch-sensitive scroll, Microsoft BlueTrack Technology
2 x AAA type
Microsoft Windows 7, Windows 8, Apple MacOS X 10.6 - 10.7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
6.5 cm
9.55 cm
3.3 cm
111 g
Storm grey
Input Device
Wireless
Bluetooth
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
8000 fps
AAA type
Alkaline
Installed Qty
2
Run Time (Up To)
9 months
Limited warranty - 3 years
5 - 80% (non-condensing)
