The Sculpt Ergonomic Desktop keyboard and mouse let you work as long as you need to, while putting less strain on your wrists or forearms. The separate number pad provides greater flexibility for workspace setup. Built with advanced ergonomics, it's designed with your comfort in mind. Works on Windows 8, Windows 7 and Windows RT*. Two AAA batteries are included.
*Compatible with Windows 11 Home/Pro and Windows 10 with latest updates.
Sculpt Ergonomic Desktop is built on advanced ergonomic principles, with a split keyboard layout that keeps wrists and forearms in a relaxed position, and a cushioned palm rest to provide wrist support. The domed keyboard shape works to reduce and correct wrist pronation that can cause pain and limited mobility.
Sculpt Ergonomic Desktop is designed for productivity, with an eye on ergonomic excellence. By providing a relaxed, comfortable computing experience, it enables you to work without the stress, strain, and discomfort of other keyboards and mice you may have used in the past.
Advanced ergonomic design
Sculpt Ergonomic Desktop is built on advanced ergonomic principles, with a split keyboard layout that keeps wrists and forearms in a relaxed position, and a cushioned palm rest to provide wrist support. The domed keyboard shape works to reduce and correct wrist pronation that can cause pain and limited mobility. -
True comfort for lasting productivity
Sculpt Ergonomic Desktop is designed for productivity, with an eye on ergonomic excellence. By providing a relaxed, comfortable computing experience, it enables you to work without the stress, strain, and discomfort of other keyboards and mice you may have used in the past. -
It's all in the angles
The natural arc keyboard layout follows the curve of your fingertips for a more natural way of typing. Reverse tilt design positions the keyboard at the correct angle to give you a straight, neutral wrist position. Additionally, the shape of the mouse is designed for maximum wrist comfort.
- Microsoft Sculpt Ergonomic Desktop - keyboard, mouse and numeric pad set - UK
- Keyboard, mouse and numeric pad set - ergonomic
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Input Device
- Keyboard
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Keys Qty
- 105
- Hot Keys Function
- Volume, mute, play/pause
- Removable palm rest, split spacebar with backspace functionality
- Pointing Device
- Mouse - optical
- Buttons Qty
- 3
- Scrolling wheel (4-way), BlueTrack Technology, right-handed, Windows touch tab
- 3-year warranty
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 3 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 39.2 cm x 22.8 cm x 5.9 cm / 842 g , Mouse: 7.94 cm x 9.82 cm x 5.67 cm / 155 g , Keypad: 9.28 cm x 13.2 cm x 1.17 cm / 106 g
Input Device
- Keyboard - wireless
- Keyboard Name
- Microsoft Sculpt Ergonomic Keyboard
- Keys Qty
- 105
- Hot Keys Function
- UK
Pointing Device
- Mouse
- Pointing Device Name
- Microsoft Sculpt Ergonomic Mouse
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Pointing Device Features
- UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, CB, RSS-210, MIC, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO
- OS Required
- Windows 10, 8, 7 and RT
- Installed Qty
- 2
- Required Qty
- 2
- Technology
- Alkaline
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
