Microsoft Sculpt Ergonomic Desktop
Built for your comfort, enabling you to increase work productivity
Quicklinx: 9210WS00 Mfr#: L5V-00006
Recommended Use: Office
Type: Keyboard, Keypad, Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
  • Windows 8 (32/64 bits)
  • Windows 8.1 (32/64 bits)
More than 50 in stock
£62.37 ex VAT
£74.84 inc VAT
Sculpt Ergonomic Desktop is built on advanced ergonomic principles, with a split keyboard layout that keeps wrists and forearms in a relaxed position, and a cushioned palm rest to provide wrist support. The domed keyboard shape works to reduce and correct wrist pronation that can cause pain and limited mobility.
Sculpt Ergonomic Desktop is designed for productivity, with an eye on ergonomic excellence. By providing a relaxed, comfortable computing experience, it enables you to work without the stress, strain, and discomfort of other keyboards and mice you may have used in the past.
  • Advanced ergonomic design
  • True comfort for lasting productivity
  • It's all in the angles
    The natural arc keyboard layout follows the curve of your fingertips for a more natural way of typing. Reverse tilt design positions the keyboard at the correct angle to give you a straight, neutral wrist position. Additionally, the shape of the mouse is designed for maximum wrist comfort.
Microsoft Sculpt Ergonomic Desktop - keyboard, mouse and numeric pad set - English - United Kingdom
Keyboard, mouse and numeric pad set - ergonomic
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard - wireless
Layout
Keys Qty
105
Hot Keys Function
Volume, mute, play/pause
Removable palm rest, split spacebar with backspace functionality
Pointing Device
Mouse - optical
Buttons Qty
3
Scrolling wheel (4-way), BlueTrack Technology, right-handed, Windows touch tab
3-year warranty
2.4 GHz
Max Operating Distance
Up to 3 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 39.2 cm x 22.8 cm x 5.9 cm / 842 g , Mouse: 7.94 cm x 9.82 cm x 5.67 cm / 155 g , Keypad: 9.28 cm x 13.2 cm x 1.17 cm / 106 g
Input Device
Keyboard - wireless
Keyboard Name
Microsoft Sculpt Ergonomic Keyboard
Keys Qty
105
Hot Keys Function
Layout
Pointing Device
Mouse
Pointing Device Name
Microsoft Sculpt Ergonomic Mouse
Buttons Qty
3
Movement Detection Technology
Optical
Pointing Device Features
UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, CB, RSS-210, MIC, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO
Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 8.1 RT, Windows 10 (32/64 bits), Apple MacOS X 10.7 or later (limited functionality), Microsoft Windows 7 (32/64 bits) (limited functionality)
Installed Qty
2
Required Qty
2
Alkaline
Limited warranty - 3 years
5 - 80% (non-condensing)
Type: Keyboard
Type: Keypad
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 50 - 100
