Microsoft Optical Mouse 200 Black USB
Quicklinx: 757ZWS00 Mfr#: JUD-00007
Easy to Set Up and Use
No software to install, no feature setup required.
Comfortable in Either Hand
Use your mouse with your left or right hand--ambidextrous design makes it comfortable either way.
Compact
Easy to carry along and use on small work spaces.
Optical Technology
High Performance Optical Technology--no mouse ball. 800 dpi optical sensor delivers greater accuracy and control.
Scroll Wheel
Move through your documents quickly without having to click on the on-screen scroll bar.
3-Button Mouse
Get quick access to the media, programs, and files you use most often with customisable buttons.
3 Year Warranty
  • Comfortable in either hand
    Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
Microsoft Optical Mouse 200 - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
5.6 cm x 10.6 cm x 3.6 cm
80 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
Up to 30 inches per second, 4000 fps
Scrolling wheel
1 x USB cable - integrated - 1.8 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
Mouse
Orientation
5.6 cm
10.6 cm
3.6 cm
80 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Performance
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play; USB 1.1
5 - 80% (non-condensing)
