Microsoft NoteBook Optical Mouse Silver 2 Button USB 5 Pack
Quicklinx: 454WWS00 Mfr#: M20-00017
Navigate in greater comfort wherever you need to work. Optical accuracy and the convenient scroll wheel ensure smooth performance.
Navigate with better speed, accuracy and reliability - the optical sensor tracks movement on nearly any surface without the hassle of clogged mouse parts. Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way. Save time and effort with the scroll wheel - navigate documents and Web pages without using the on-screen scroll bar.
  • Optical technology
  • Comfortable in either hand
  • Scroll wheel
Microsoft Notebook Optical Mouse - mouse - USB - silver
Mouse
Packaged Quantity
5 (specifications are for single item)
Wired - USB
Silver
5.4 cm x 8.7 cm x 3.3 cm
0.2 kg
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
400 dpi
Scrolling wheel
Microsoft Windows 2000 Server, Microsoft Windows 2000 Professional, Microsoft Windows 98/ME, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.1 - 10.1.3
Microsoft Certification
Compatible with Windows 7
3-year warranty
Packaged Quantity
Mouse
5.4 cm
8.7 cm
3.3 cm
0.2 kg
Silver
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
400 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
UL, GOST, cUL, FCC
System Requirements Details
Windows 2000 Pro/Server - Pentium - 233 MHz - RAM 128 MB , Windows 98/ME - Pentium - 233 MHz - RAM 128 MB , Windows XP Home/Pro - Pentium - 233 MHz - RAM 128 MB
Limited warranty - 3 years
-10 °C
5 - 80%
