Create, study, work and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life plus a softer, ultra-portable design with rounded edges.
A laptop in tablet form, Surface Pro brings together the best of Microsoft in one awesome new device.
Run all the same programs you have come used to with Windows 10. Run the full Office suite and your line of business applications and choose from thousands of apps available in the Windows Store. From The Economist to Wall Street Journal to Dropbox, you'll get amazing apps built specifically for Windows 10. Don’t forget to check back often for new and improved apps.
The Surface pro has all the fantastic security and manageability features that you expect from Microsoft. BitLocker encrypts your hard drive's data, helping to keep your stuff safe. Install applications and connect with accessories and printers, just like you always have. Join a corporate domain for full access to your work network.
Enjoy fast, powerful performance and stunning visuals. The Intel processor was built using the latest technologies, including HD graphics, to deliver with impressive speed and responsiveness.
A stunning entertainment experience awaits you with a 16:9 widescreen, ClearType full HD display with 1080p resolution. Movies and photos leap from the screen in bold color and sharp contrast. The Surface display is incredibly responsive to touch, pen and keyboard. Seamlessly switch between input modes in fluid motion.
Get creative with drawing and note taking in applications such as OneNote. Mark up your PowerPoint presentations, PDFs, and documents just like you would on paper.
Included with the Surface Pro is the Signature Type Cover in Alcantara material - a perfect blend of sophisticated style, comfort, and technology. Fully redesigned, it’s thinner and lighter, with improved magnetic stability. It also has a mechanical keyboard with optimal key spacing for fast and fluid typing, plus an enlarged track pad that supports gestures and 5-point touch for precision control and navigation and a magnetic hinge for stable typing.
Uncompromising mobility
Create, study, work, and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life, plus a softer, ultra-portable design with rounded edges. -
Exceptional power and performance
Surface Pro delivers even more speed and performance thanks to a powerful Intel Core processor - with up to 50% more battery life than Surface Pro 4 and 2.5x more performance than Surface Pro 3. -
A vibrant display that inspires creativity
Watch your ideas come to life in brilliant color and razor-sharp resolution on the 12.3" PixelSense display with a stunning screen. -
Whisper quiet
Surface Pro i5 models feature a fanless cooling system, so you can work or stream your favorite shows in peace.
- Microsoft Surface Pro - Education Bundle - 12.3" - Intel Core i5 - 7300U - 8 GB RAM - 256 GB SSD - with Surface Pro Type Cover (black) and Surface Pen
- Product Type
- Tablet - with detachable keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i5 (7th Gen) - 7300U / 2.6 GHz, up to 3.5 GHz / 3 MB Cache
- Memory
- 8 GB LPDDR3
- Storage
- 256 GB SSD
- Display
- 12.3" touchscreen 2736 x 1824
- Graphics
- Intel HD Graphics 620
- Input Device
- Keyboard, Surface Pen
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- Up to 13.5 hours
- Accelerometer, ambient light sensor, gyro sensor
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip
- 29.2 cm x 20.1 cm x 0.85 cm
- 770 g
- Localisation
- Region: United Kingdom, Ireland
- Pricing Type
- Academic, commercial
- Specific Absorption Rate (SAR)
- 0.867 W/kg (body)
- Limited warranty - 1 year
- Bundled with
- Surface Pro Type Cover (black) and Surface Pen
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
- Bundled with
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7300U / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- RAM
- 8 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD
Display
- 12.3"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2736 x 1824
- Widescreen
- Image Aspect Ratio
- 3:2
- PixelSense
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 8 Megapixel (rear), 5 Megapixel (front)
- Camera Features
- Autofocus, Windows Hello
- Sound
- Stereo speakers, two microphones
- Dolby Audio Premium
Input
Communications
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Run Time
- Up to 13.5 hours
Connections & Expansion
- Interfaces Details
- USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , Dock , SurfaceConnect
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft 365 (30 days trial)
- Integrated Options
- Dockable
- Security
- Studio Mode
- Included Accessories
- Power adapter, keyboard
- SAR Value
- 0.867 W/kg (body)
- 0.867 W/kg (body)
- Localization
- Pricing Type
- 770 g
Sustainability Information
- TCO Certified
