Natural Ergonomic Keyboard 4000 has been expertly crafted to allow you to work in a more natural position. The new Gull Wing design features a 14-degree gable, a natural arc and a curved key bed - bringing the keys closer to your fingers to reduce reach and unnecessary motion, while encouraging a more natural typing position. It also comes equipped with an optional palm lift for a seven-degree reverse slope and a cushioned wrist rest that encourages better arm and wrist alignment.
Zoom
Get a closer look - zoom in quickly and accurately with the intuitive Zoom feature. -
Customizable Hot Keys
Perform common tasks, like opening documents and replying to e-mail, with the touch of a button. -
Improved Number Pad
Commonly used symbols such as equal sign, left and right parentheses and "Backspace" are in quick reach, just above the number pad. -
Ergonomic Design
Type in total comfort - ergonomic design encourages natural wrist and arm alignment so you can work without discomfort. -
Device Stage
Quickly and easily access common tasks, including product information, registration, settings and more for popular devices such as cell phones, cameras, printers, and mouse, keyboard and webcam products. -
Internet Hot Keys
With the touch of a button you can quickly access the Internet. -
Taskbar Favorites
Easily access programs in the taskbar with convenient keyboard hot keys. Applications can be easily rearranged by clicking and dragging, and the keys will automatically adapt to the new location. -
E-mail and Internet Hot Keys
Touch a button to quickly access e-mail and the Internet. -
MultiMedia Keys
Quickly and easily access and control all of your media from your keyboard. -
Lockable F Keys
Lock your F keys to avoid engaging them unintentionally. -
Integrated Palm Rest
Get better support with this plush, integrated palm rest. -
Cutting-Edge Design
Whether you're at work or play, improve your performance with cutting-edge Microsoft technology.
- Microsoft Natural Ergonomic Keyboard 4000 - keyboard - QWERTY - UK - black, silver Input Device
- Keyboard - ergonomic
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- QWERTY UK
- Keys Qty
- 105
- Hot Keys Function
- Internet browsing, multimedia, programmable, calculator, zoom, e-mail, volume, search, mute
- Palm rest, spillproof, zoom slider
- Black, silver
- 26.2 cm x 50.3 cm x 8.3 cm
- 1.3 kg
- Microsoft Certification
- Certified for Windows Vista
- 3-year warranty
- Interface
- USB
- Keys Qty
- 105
- Hot Keys Function
- QWERTY UK
- Region
- United Kingdom
- 26.2 cm
- 50.3 cm
- 8.3 cm
- 1.3 kg
- Connections
- 1 x USB - 4 pin USB Type A
- Black, silver
- Cables Included
- 1 x USB cable - 1.5 m
- Compatibility
- MS Windows XP Media Centre compatible
- UL, VCCI, BSMI, GOST, cUL, ICES-003, NOM, WHQL, CB, EMC, MIC, FCC, ISO 9002, ACA
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Included Software
- Microsoft IntelliType Pro
- OS Required
- Microsoft Windows 2000, Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Tablet PC Edition, Microsoft Windows XP Media Center Edition, Apple MacOS X 10.2 - 10.4.x
- Limited warranty - 3 years
- 0 °C
- 35 °C
- 5 - 80%
Customer reviews
Write a review for the Microsoft Natural Ergonomic 4000 here!
Not spill proof!
Reviewed by . Review Posted 09/03/2009
A great keyboard to use, buy it fails totally at the first split of water on the keys. The MS Comfort Curve 2000 is less than half the price and "Split-Proof". For such an expensive keyboard, would it be too much to make is split proof???
Overall
Ease of use
Value for money
Excellent Value and performance
Reviewed by Paul. Review Posted 28/04/2008
This keybord is the best keyboard I have ever used. I have the original Maicrosoft Ergo in cream and this just about beats it. I play COD4 in a clan and this is the best keyboard for gaming by a country mile. Forget Saitek or Logitech and all the other "gaming" keyboards, this is by for the best and most comfortable. Buy one you won't be disapointed.
Overall
Ease of use
Value for money
Great keyboard, highly recommended
Reviewed by Paulo. Review Posted 02/04/2008
This must be the best keyboard I've ever tried! Perfect ergonomic design, feels great and is extremely responsive. Only negative so far is the Space key, which feels a little stuck, and you have to press it a little harder when hitting it on the sides, as in the middle it just presses down smoothly.
Highly recommend it!
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
