Microsoft Modern USB-C Speaker USB Port - Black
Quicklinx: GFWLWS00 Mfr#: 8KZ-00002
Add high-quality audio to your workspace wherever you are. Certified for Microsoft Teams, the Modern USB-C speaker seamlessly integrates with your Surface or Windows 10 PC for clear, reliable calls and great sound for music.
  • Intuitive meeting controls
    Featuring easy-to-use buttons, including mute control with status light to easily see whether you can be heard.
  • Optimized for voice
    High-quality speakers are optimal for meetings, calls, and music.
  • Certified for Microsoft Teams
    Seamlessly integrates with your Surface or other Windows 10 PC. With quick-access control panel for Microsoft Teams calls.
  • Noise-reducing microphone
    The omnidirectional, background noise-reducing microphone captures your voice better than your PC alone.
  • Premium, compact design
    Cable storage and carrying case doesn't crowd your workspace or bag and is out of the way on calls.
Microsoft Modern USB-C Speaker - speakerphone
Speakerphone - wired - USB-C
Recommended Use
Computer - communication
Matte black
Wired
Audio Specifications
Frequency Response 200 - 20000 Hz
Microphone Operation Mode
Omni-directional
Microphones Included
2
Controls
Mute, volume control, Microsoft Teams button
Software Certification
1-year warranty
13.8 cm
7 cm
2.9 cm
191 g
Matte black
Body Material
Fabric, silicone
Recommended Use
Audio Output
Wired
Frequency Response
200 - 20000 Hz
Max Sound Pressure
83 dB
Diaphragm
50 mm
Microphone
Built-in
Omni-directional
2
Remote Control
Controls
Connector Type
USB (24 pin USB-C)
Cable
Cable Length
68 cm
Cable Details
USB-C cable - 68 cm
Limited warranty - 1 year
