Ergonomic Keyboard's subtle changes to the keytop geometry, split space bar, and naturally arched shape protect you from wrist and hand strain, and improve your typing form to speed up your words per minute.
The keyboard's double-cushioned palm rest uses a special, ultra-durable version of Alcantara a unique, proprietary material, sourced only in Italy, with aesthetic, sensory, and technical qualities unlike anything you've ever experienced.
Protect your hands and wrists
Ergonomic Keyboard's subtle changes to the keytop geometry, split space bar, and naturally arched shape protect you from wrist and hand strain, and improve your typing form to speed up your words per minute. -
Intersection of design and functionality
The keyboard's double-cushioned palm rest uses a special, ultra-durable version of Alcantara a unique, proprietary material, sourced only in Italy, with aesthetic, sensory, and technical qualities unlike anything you've ever experienced. -
Carefully crafted experience
The key sound, stiffness, and texture provide a stable and quiet typing experience with optimized grip. Optimized feedback and return force prevents accidental presses and allows for smooth, consistent action.
- Microsoft Surface Ergonomic Keyboard - keyboard - English - United Kingdom - alcantara grey
- Keyboard - wireless - ergonomic
- Interface
- Bluetooth 4.0
- Layout
- Hot Keys Function
- Calculator, volume, search, mute, screen lock, play/pause, backlight control, settings, page up, page down
- Alcantara grey
- 46.014 cm x 22.922 cm x 3.473 cm
- 1.01 kg
- Pricing Type
- Commercial
- 1 year warranty
- Interface
- Bluetooth 4.0
- Max Operating Distance
- Up to 10 m
Input Device
- Hot Keys Function
- Layout
- Palm Rest
- 46.014 cm
- 22.922 cm
- 3.473 cm
- 1.01 kg
- Alcantara grey
- AES-128
- Pricing Type
- Commercial
- OS Required
- Windows 10
- AAA type
- Installed Qty
- 2
- Required Qty
- 2
- Technology
- Alkaline
- Limited warranty - 1 year
