Microsoft LifeChat LX-4000 for Business 50 PACK
MICROSOFT LYNC OPTIMISED
Quicklinx: 7CXFWS00 Mfr#: N6J-00001
You can tune in online and in life. The single earpiece lets you hear what's going on around you and still take care of business - whether that is making video calls or listening to music while working. The ultra-wideband digital audio provides clear, accurate sound. The highly sensitive, noise canceling microphone gives you the confidence that you are being heard even when you're surrounded by a noisy work environment.
  • Selective sound
    Single earpiece lets you hear everything you need to hear.
  • Noise canceling microphone
    Your voice will clearly cut through, and you can easily select your position.
  • In-line volume and microphone controls
    Adjust volume or mute on the fly with handy in-line controls.
  • Plug-and-play simplicity
    No software is needed, just plug it in and you're ready.
  • Comfortable
    You'll forget you're wearing it. And the call indicator light lets people know you're "busy".
Microsoft LifeChat LX-4000 for Business - headset
Headset - wired
Packaged Quantity
50 (specifications are for single item)
Recommended Use
Computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume
Microsoft Certification
Compatible with Windows 7
3-year warranty
Packaged Quantity
Headset - wired
Recommended Use
Computer
Audio Output
Full size
Wired
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Mute, volume
Connector Type
Headset (4 PIN USB Type A)
Limited warranty - 3 years
Resources
The following resources are available for the Microsoft LifeChat LX-4000 for Business 50 PACK
