You can tune in online and in life. The single earpiece lets you hear what's going on around you and still take care of business - whether that is making video calls or listening to music while working. The ultra-wideband digital audio provides clear, accurate sound. The highly sensitive, noise canceling microphone gives you the confidence that you are being heard even when you're surrounded by a noisy work environment.
Selective sound
Single earpiece lets you hear everything you need to hear. -
Noise canceling microphone
Your voice will clearly cut through, and you can easily select your position. -
In-line volume and microphone controls
Adjust volume or mute on the fly with handy in-line controls. -
Plug-and-play simplicity
No software is needed, just plug it in and you're ready. -
Comfortable
You'll forget you're wearing it. And the call indicator light lets people know you're "busy".
- Microsoft LifeChat LX-4000 for Business - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Microphone
- Boom
- Controls
- Mute, volume
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Product Type
- Headset - wired
- Recommended Use
- Computer
Audio Output
- Full size
- Wired
- Sound Output Mode
- Mono
Microphone
- Boom
Remote Control
- Controls
- Mute, volume
- Connector Type
- Headset (4 PIN USB Type A)
- Limited warranty - 3 years
