Enjoy a superior HD video quality with the LifeCam Studio, which includes a 1080p HD sensor. But great video is about more than HD. Keep your subject crisp with autofocus, from four inches to infinity. Shoot with great accuracy in wide angle with the LifeCam precision glass element lens. And, to make filming even easier, LifeCam features TrueColor Technology, which means your video remains bright and colorful in virtually all light conditions while ClearFrame Technology provides smooth and detailed footage. Use the built-in High-Fidelity Microphone to bring it all together: the vivid sights, colors, and sounds of real life.
High-precision glass element lens
Wide-angle glass element lens is designed for advanced, high-precision optics. -
TrueColor technology
Automatically delivers bright and colorful video, in virtually all lighting conditions. -
ClearFrame technology
ClearFrame technology is designed for smooth, detailed video. -
High-fidelity microphone
High-fidelity microphone is designed for more natural, detailed audio. -
Windows live photo gallery
Easily upload a photo that you can edit, tag, and share with friends and family.
- Microsoft LifeCam Studio - webcam
- Webcam
- Audio
- Yes: built-in microphone
- 6 cm x 4.5 cm x 11.4 cm
- 128 g
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Optical Sensor Type
- CMOS
- Focus Adjustment
- Automatic (min distance 10 cm)
- USB 2.0
- Cables Included
- 1 - USB cable - 1.83 m
- 720p HD movie recording, TrueColor Technology, ClearFrame Technology, 1080p Full HD movie recording
- 3-year warranty
- Microsoft Certification
- Compatible with Windows 7
- Environmental Parameters (operating)
- 0 °C - 40 °C; 5 - 80% (non-condensing) relative humidity
- Webcam
- Audio Support
- Wired
- 6 cm
- 4.5 cm
- 11.4 cm
- 128 g
Camera
- Max Digital Video Resolution
- 1920 x 1080
- Still Image Capture Resolution
- 2560 x 2048
Image Sensor
- CMOS
Lens Construction
- Focus Adjustment
- Automatic
- Min Focus Distance
- 10 cm
- Computer Interface
- USB 2.0
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable - 1.83 m
- UL, VCCI, ISO 9001, GOST, cUL, ICES-003, ISO 14001, WHQL, CB, MIC, FCC, WEEE, UkrSEPRO
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista SP1 or later
- System Requirements Details
- Windows XP/Vista/7 - dual core processor - 1.6 GHz - RAM 2 GB - HD 1.5 GB
- Limited warranty - 3 years
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 5 - 80% (non-condensing)
