Microsoft Excel Home and Student 2010 32-bit/x64 DVD
Quicklinx: 70RRWS00 Mfr#: 79C-00303
With the Sparklines feature, you can create small charts in a single cell to quickly discover patterns in your data. The Slicer feature gives you a rich visualization of your PivotTable view so you can dynamically segment and filter the data to display precisely what you need. With the search filter, you can spend less time sifting through large data sets in your tables and PivotTable views, and more time analyzing data.Conditional formatting gives you more control over styles and icons, improved data bars, and the ability to highlight specific items in a few clicks. The ability to display different data views directly in a PivotChart, independent of PivotTable views, helps you analyze and capture the most compelling picture of your numbers. The Microsoft Office Backstage view replaces the traditional File menu to let you save, share, print, and publish your workbooks with just a few clicks.
