Enjoy the freedom and convenience of wireless technology. Confidently roam up to 15 feet away from your PC while maintaining a strong wireless connection. Or, take the mouse separately to use with a laptop while traveling - the tiny transceiver conveniently snaps into the bottom of the mouse when it's time to pack up and go. Setting up the keyboard and mouse is simple - just insert the batteries, plug in the tiny transceiver, and start typing! This keyboard also has Advanced Encryption Standard (AES), which is designed to help protect your information by encrypting your keystrokes.
Reliable wireless connection
Enjoy the 2.4-gigahertz (GHz) wireless technology, which delivers a reliable connection with up to a 15 foot range, with virtually no interference. -
Advanced Encryption Standard (AES) 128-bit encryption
This keyboard features Advanced Encryption Standard (AES) technology, which is designed to help protect your information by encrypting your keystrokes. Each keyboard is permanently paired with its receiver at the factory - no key information is ever shared over the air. -
Windows shortcut keys
Quickly access frequently used tools, like the calculator, zoom and audio controls by using shortcut keys. -
Designed for comfort
In either hand Superior comfort that's designed to fit your right or left hand. -
Microsoft optical technology
Precise optical tracking technology provides highly responsive cursor control. -
Snap-in transceiver
Plug the wireless receiver into your computer's USB port when you're ready to work. Then snap it into the bottom of your mouse when you travel, and the mouse will automatically turn off. -
Battery life indicator
Avoid getting caught with a dead battery. The battery status indicator glows red when the battery is running low. -
Scroll wheel
Move through documents and webpages quickly. -
Power switch
Turn off your mouse to extend battery life. -
Windows start screen key
Simply press the Windows start screen key to view your apps and start screen. -
Longer battery life
Experience fewer interruptions with up to 15 months of battery life for your keyboard.
- Microsoft Wireless Desktop 850 for Business - keyboard and mouse set
- Keyboard and mouse set
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Connectivity Technology
- Wireless
- Hot Keys Function
- Calculator, volume, mute, play/pause, Windows 8, Start key
- Pointing Device
- Mouse - wireless - optical
- Buttons Qty
- 3
- 3-year warranty
- Interface
- 2.4 GHz
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 48.6 cm x 22.7 cm x 4.57 cm / 601 g , Mouse: 5.83 cm x 11.3 cm x 3.96 cm / 65.9 g , Wireless receiver: 2.76 cm x 1.5 cm x 0.689 cm / 2.8 g
Input Device
- Wireless
- Keyboard Name
- Microsoft Wireless Keyboard 850
- Hot Keys Function
Pointing Device
- Mouse - wireless
- Pointing Device Name
- Microsoft Wireless Mouse 1000
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Included Software
- Drivers & Utilities
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.4 - 10.7, Windows 8, Windows 10
- AAA type
- Installed Qty
- 2
- Technology
- Alkaline
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
