With its ultra-thin and modern look, the Designer Bluetooth Desktop complements the look of your desk. It wirelessly pairs to your laptop or tablet with the latest Bluetooth Smart technology - instantly connecting without wires or dongles to manage. A full-sized keyboard with built-in number pad and mouse will keep you productive at your desk.
Even with its minimalist design, this keyboard gives you a robust typing experience with chiclet-style, soft touch keys. Media keys are included, so you can easily control music and videos.
Modern design
Ultrathin and modern design complements your desktop. -
Bluetooth Smart
Clutter-free and reliable experience utilizing the latest in Bluetooth 4.0 technology. -
Media Center
Control media playback from your keyboard. -
Built-in number pad
The keyboard is full-sized with a built-in number pad -
BlueTrack Technology
Combines the power of optical with the precision of laser for remarkable tracking on virtually any surface. -
Designed for either hand
Ambidextrous design allows you to control your mouse in either hand.
- Microsoft Designer Bluetooth Desktop - keyboard and mouse set - UK
- Keyboard and mouse set
- Interface
- Bluetooth 4.0
- Input Device
- Keyboard
- Connectivity Technology
- Wireless
- Localization and Layout
- UK
- Keys Qty
- 105
- Hot Keys Function
- Mute, play/pause, page up, page down, volume -, volume +, Start key
- Numeric Keypad
- Bluetooth 4.0 compatible
- Pointing Device
- Mouse - wireless - optical
- Buttons Qty
- 3
- Scrolling wheel, BlueTrack Technology, right and left-handed
- 3-year warranty
- Interface
- Bluetooth 4.0
- Max Operating Distance
- Up to 10 m
- Dimensions (WxDxH) / Weight
- Keyboard: 38.9 cm x 11.2 cm x 1.98 cm / 420 g , Mouse: 6.01 cm x 10.7 cm x 2.58 cm / 80 g
Input Device
- Keyboard - wireless
- Keyboard Name
- Microsoft Designer Bluetooth Keyboard
- Keys Qty
- 105
- Hot Keys Function
- UK
- Bluetooth 4.0 compatible numeric keypad
Pointing Device
- Mouse - wireless
- Pointing Device Name
- Microsoft Designer Bluetooth Mouse
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Movement Resolution
- 1000 ppi
- Pointing Device Features
- FCC Class B certified, VCCI, ISO 9001, ISO 14001, MIC, NTRA, KCC, WEEE, ANATEL, TELEC, REACH, CITC, NCC, iDA, ICASA, TRA, Subtel
- OS Required
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.8 or later, Windows 8.1 (32/64 bits), Microsoft Windows RT 8.1, Microsoft Windows RT 8, Android 4.2 (Jelly Bean) or later, Windows 10 (32/64 bits), Apple iOS 8 or later
- AAA type
- Installed Qty
- 2
- Technology
- Alkaline
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
BLV2 043648 Condition: Customer return - item has been used and shows signs of use |
£28.78 |
Ref:
BLV2 043786 Condition: Customer return - item has been opened but is in excellent condition |
£40.06 |
Ref:
BLV2 043794 Condition: Customer return - item has been opened but is in excellent condition |
£40.63 |
Ref:
BLV2 043871 Condition: Customer return - item has been opened but is in excellent condition |
£44.01 |
Ref:
BLV2 043942 Condition: Customer return - item has been opened but is in excellent condition |
£49.09 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
