Work anywhere with this full-featured mouse, which delivers comfort in either hand and the precise control of Microsoft BlueTrack Technology at a great value.
Microsoft BlueTrack Technology combines the power of optical with the precision of laser for remarkable tracking on virtually any surface. -
Comfort and durability
Rubber side grips and a contoured shape for either hand! Dust-resistant design allows you to track confidently. -
5 customizable buttons
Reassign any button to fit your needs. Quick access to the media, programs, and files you use most often. -
Tilt wheel
Easy horizontal and vertical scrolling!
- Microsoft Comfort Mouse 4500 for Business - mouse - USB - black, anthracite
- Mouse
- Connectivity Technology
- Wired - USB
- Black, anthracite
- Movement Detection Technology
- Optical
- Buttons Qty
- 5
- Movement Resolution
- 1000 dpi
- Scrolling wheel, rubber side grips, Microsoft BlueTrack Technology
- Cables Included
- 1 x USB cable - integrated
- OS Required
- Apple MacOS X 10.2, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
- 3-year warranty
- Mouse
- Black, anthracite
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 5
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Cables Included
- OS Required
- Limited warranty - 3 years
