Microsoft Comfort Mouse 3000 For Business
Quicklinx: 7Y6WWS00 Mfr#: 5AJ-00003
The reliability and comfort of the Comfort Mouse 3000 will help you get the job done.
  • Comfortable in either hand
    Rubber side grips and a contoured shape for either hand.
  • BlueTrack technology
    Take advantage of BlueTrack technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
  • Wired reliability
    Designed for trouble-free performance, eliminating the worry of battery life.
  • Three customizable buttons
    Give yourself some shortcuts.
  • Savings
    Reduce costs with volume pricing.
Microsoft Comfort Mouse 3000 for Business - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
6.6 cm x 11.5 cm x 4.1 cm
92 g
Movement Detection Technology
Optical
Buttons Qty
3
Performance
8000 fps, 28 G maximum acceleration
Programmable buttons, scrolling wheel, Microsoft BlueTrack Technology
1 x USB cable - integrated - 2 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.4.x - 10.6.x
3-year warranty
Mouse
Orientation
6.6 cm
11.5 cm
4.1 cm
92 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Performance
1 x USB - 4 pin USB Type A
UL, VCCI, BSMI, ISO 9001, GOST, cUL, ICES-003, ISO 14001, CB, EMC, FCC, KCC, WEEE, ACA, REACH
Limited warranty - 3 years
5 - 80% (non-condensing)
