The Comfort Curve Keyboard 3000 is ergonomist approved and helps provide a more natural wrist position that just feels right from the first time you use it. The slim, glossy design saves space and makes a statement on your desktop.
It's familiar, yet modern
All the keys are the same size and in a familiar place, even with the Comfort Curve. The slim, glossy design saves space and makes a statement on your desktop. -
Ergonomist-approved Comfort Curve design
The Microsoft Comfort Curve encourages natural wrist posture, plus it is easy to use. -
Easy-access media keys
Control your music and videos, and open the calculator with the touch of a key.
- Microsoft Comfort Curve Keyboard 3000 for Business - keyboard - UK
- Keyboard - ergonomic
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Keys Qty
- 105
- Hot Keys Function
- Calculator, volume, play/pause
- 47 cm x 17.5 cm x 3.3 cm
- 0.6 kg
- 3-year warranty
- Interface
- USB
Input Device
- Keys Qty
- 105
- Hot Keys Function
- UK
- 47 cm
- 17.5 cm
- 3.3 cm
- 0.6 kg
- Cables Included
- 1 x USB cable - 1.5 m
- UL, VCCI, BSMI, ISO 9001, GOST, cUL, ICES-003, ISO 14001, CB, KCC, WEEE, REACH
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Limited warranty - 3 years
- 0 °C
- 35 °C
- 5 - 80% (non-condensing)
