Microsoft Bluetooth Notebook Mouse 5000 for Business
Quicklinx: 7CWBWS00 Mfr#: 3ZH-00002
Microsoft's most portable wireless notebook mouse connects directly to a Bluetooth PC without a transceiver, freeing up USB ports for other devices.
  • Transceiver free convenience
    Enjoy reliable, transceiver-free wireless connection to your Bluetooth PC.
  • High definition laser technology
    Microsoft high definition laser mouse products are more precise, more responsive, and deliver smoother tracking.
  • Battery life indicator
    You won't get caught with a dead battery - the battery status LED Indicator glows red when the battery is running low.
  • Ergonomic design
    Point and click in comfort - ergonomic design helps you work longer without discomfort.
  • Back button
    Use the Back button to easily navigate between folders and Web pages, or press the wheel for auto-scroll.
  • Scroll wheel
    Save time and effort with the scroll wheel - navigate documents and Web pages without using the on-screen scroll bar.
  • Comfort for either hand
    Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
  • On/off button
    Turn your mouse device off to extend battery life even longer.
  • 4 buttons
    Use the Back button to easily navigate folders or web pages, and press the scroll wheel for AutoScroll.
  • Designed for notebook PCs
    Compact and comfortable, our handy notebook and laptop products are designed for convenience and mobility.
Microsoft Bluetooth Notebook Mouse 5000 for Business - mouse - Bluetooth
Mouse
Wireless - Bluetooth
Orientation
Right and left-handed
Movement Detection Technology
Laser
Buttons Qty
4
Movement Resolution
1000 dpi
Scrolling wheel, rubber side grips, High Definition Laser Technology, battery indicator, on/off power switch
Apple MacOS X 10.2 or later, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
3-year warranty
Mouse
Orientation
Input Device
Wireless
Bluetooth
Max Operating Distance
Up to 10 m
Laser
Buttons Qty
4
Movement Resolution
1000 dpi
Limited warranty - 3 years
