Navigate quickly and easily with the convenient scroll wheel and work on virtually any surface. Get one-click access to frequently-used features with customizable buttons.
Optical technology
Navigate with better speed, accuracy and reliability - the optical sensor tracks movement on nearly any surface without the hassle of clogged mouse parts. -
Scroll even faster
Move through your documents quickly without having to click on the scroll bar. -
Comfortable in either hand
Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way. -
Customizable buttons
Get quick access to the media, programs, and files you use most often with customizable buttons. -
Device stage
Quickly and easily access common tasks, including product information, registration, settings and more for popular devices such as cell phones, cameras, printers, and mouse, keyboard and webcam products. -
Ergonomic design
Point and click in comfort - ergonomic design helps you work longer without discomfort.
- Microsoft Basic Optical Mouse for Business - mouse - PS/2, USB - white
- Mouse
- Connectivity Technology
- Wired - PS/2, USB
- White
- Orientation
- Right and left-handed
- 5.8 cm x 11.3 cm x 3.9 cm
- 117 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 800 dpi
- Performance
- 3000 fps, up to 20 inches per second
- Programmable buttons, scrolling wheel
- Cables Included
- 1 x USB cable - integrated - 1.8 m , 1 x mouse adapter - external
- OS Required
- Microsoft Windows 98/2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Tablet PC Edition, Microsoft Windows XP Media Center Edition, Microsoft Windows Vista, Apple MacOS X 10.1 - 10.4.x
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Orientation
- 5.8 cm
- 11.3 cm
- 3.9 cm
- 117 g
- White
Input Device
- Wired
- Interface
- PS/2, USB
- Optical
- Buttons Qty
- 3
- 800 dpi
- Performance
- 1 x USB - 4 pin USB Type A , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
- Cables Included
- UL, VCCI, BSMI, GOST, cUL, ICES-003, CB, MIC, FCC, WEEE, REACH
- OS Required
- Limited warranty - 3 years
- -10 °C
- 40 °C
- 5 - 80% (non-condensing)
