Brand
Microsoft Basic Optical Mouse - Black
Quicklinx: 91M8WS00 Mfr#: P58-00057
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC
£9.99 ex VAT
£11.98 inc VAT
Microsoft Optical Technology replaces the old-fashioned mouse ball and works on virtually any surface. Easy and comfortable to use, Basic Optical Mouse is a good choice for value.
Now you can experience the benefits of the world's most powerful optical technology. The Microsoft optical sensor replaces your old-fashioned mouse ball. The ambidextrous design is comfortable whether you mouse with your left or right hand.
  • Optical technology
    Navigate with better speed, accuracy and reliability. The optical sensor tracks movement on nearly any surface.
  • Scroll even faster
    Move through your documents quickly without having to use the on-screen scroll bar.
  • Comfortable in either hand
    Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
  • Customizable buttons
    Get quick access to the media, programs and files you use most often.
  • Device stage
    Quickly and easily access common tasks, including product information, registration, settings and more for popular devices such as mobile phones, cameras and printers, and mouse, keyboard and webcam products.
  • Ergonomic design
    Point and click in comfort. Ergonomic design helps you work longer without discomfort.
Microsoft Basic Optical Mouse - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
5.6 cm x 11.1 cm x 3.7 cm
95 g
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Performance
3000 fps
Programmable buttons, scrolling wheel
1 x USB cable - integrated - 1.7 m
Apple MacOS X 10.1.5 or later, Microsoft Windows 98/2000/XP/Vista/7
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
5.6 cm
11.1 cm
3.7 cm
95 g
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Performance
3000 fps
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
-10 °C
5 - 80% (non-condensing)
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
