Micron P400m 200GB SATA 2.5" Solid State Drive
Quicklinx: 998NWS00 Mfr#: MTFDDAK200MAN-1S1AA
Engineered to be an enterprise workhorse, the Micron P400m SSD utilizes advanced features and SSD-specific NAND to deliver powerful performance. Tuned for enterprise steady-state 24/7 workloads, the Micron P400m is built using select Micron MLC NAND that's been probed at the wafer level and tested again at the screen-in level to work optimally in enterprise-class SSDs. The result? Faster steady-state performance, increased reliability, and longer life of the NAND. The Micron P400m features data path protection, power protection, RAIN, and advanced read/write management technology.
Micron Enterprise SATA SSD P400m - SSD - 200 GB - SATA 6Gb/s
Solid state drive - internal
200 GB
NAND Flash Memory Type
Multi-level cell (MLC)
2.5" x 1/12H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Native Command Queuing (NCQ), password authentication, DMA supported, Dynamic and Static Wear Leveling, Secure Erase function, multi-level cell (MLC), S.M.A.R.T.
69.85 mm x 100.5 mm x 7 mm
125 g
200 GB
2.5" x 1/12H
SATA 6Gb/s
69.85 mm
100.5 mm
7 mm
125 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
350 MBps (read) / 300 MBps (write)
4KB Random Read
55000 IOPS
4KB Random Write
16000 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/12H
Power Consumption
7.5 Watt (active)
TUV, VCCI, C-Tick, EN 60950, EN55022, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, UL 60950-1 Second Edition, KCC, WEEE, BSMI CNS 13438, FCC CFR47 Part 15 B, IEC 60950-1 Second Edition
70 °C
5 - 95% (non-condensing)
Shock Tolerance
1500 g @ 1ms
Vibration Tolerance
3.1 g @ 2-500 Hz (operating)
