Micron Crucial Micron 5300 PRO - Solid state drive - 480 GB - internal - M.
Quicklinx: FLTRWS00 Mfr#: MTFDDAV480TDS-1AW1ZABYY
The world’s first enterprise SATA SSD with 96-layer NAND, the Micron 5300 SATA series of SSDs lets you modernize your data center and cloud servers now. Get proven architecture, plus new NAND, features and models you need to power the future.
  • Solid data security
    Secure your data with power-loss protection, and enterprise data path protection.
  • Strong read-intensive, mixed-use performance
    Optimizations drive strong performance for media streaming, business analytics, OLTP, and block and object storage.
Micron 5300 PRO - SSD - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
NAND Flash Memory Type
3D triple-level cell (TLC)
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
Adaptive thermal monitoring, RAIN technology, Hot-Plug Support, Read-Intensive Endurance, Enterprise Data Path Protection, ATA security, Flex Capacity, 96-layer 3D NAND technology
22 mm x 80 mm x 3.8 mm
10 g
5-year warranty
480 GB
M.2 2280
SATA 6Gb/s
22 mm
80 mm
3.8 mm
10 g
Performance
SSD Endurance
1324 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 410 MBps (write)
4KB Random Read
85000 IOPS
4KB Random Write
36000 IOPS
Average Latency
100 µs
Reliability
MTBF
3,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
M.2 2280
Power Consumption
3 Watt (sequential read) , 3.9 Watt (sequential write)
Limited warranty - 5 years
70 °C
