The world’s first enterprise SATA SSD with 96-layer NAND, the Micron 5300 SATA series of SSDs lets you modernize your data center and cloud servers now. Get proven architecture, plus new NAND, features and models you need to power the future.
Solid data security
Secure your data with power-loss protection, and enterprise data path protection. -
Strong read-intensive, mixed-use performance
Optimizations drive strong performance for media streaming, business analytics, OLTP, and block and object storage.
 - Micron 5300 PRO - SSD - 480 GB - SATA 6Gb/s
 - Solid state drive - internal
- Capacity
 - 480 GB
- NAND Flash Memory Type
 - 3D triple-level cell (TLC)
- Form Factor
 - M.2 2280
- Interface
 - SATA 6Gb/s
- Data Transfer Rate
 - 600 MBps
 - Adaptive thermal monitoring, RAIN technology, Hot-Plug Support, Read-Intensive Endurance, Enterprise Data Path Protection, ATA security, Flex Capacity, 96-layer 3D NAND technology
 - 22 mm x 80 mm x 3.8 mm
 - 10 g
 - 5-year warranty
- Capacity
 - 480 GB
- Form Factor
 - M.2 2280
- Interface
 - SATA 6Gb/s
 - 22 mm
 - 80 mm
 - 3.8 mm
 - 10 g
Performance
- SSD Endurance
 - 1324 TB
- Drive Transfer Rate
 - 600 MBps (external)
- Internal Data Rate
 - 540 MBps (read) / 410 MBps (write)
- 4KB Random Read
 - 85000 IOPS
- 4KB Random Write
 - 36000 IOPS
- Average Latency
 - 100 µs
Reliability
- MTBF
 - 3,000,000 hours
- Non-Recoverable Errors
 - 1 per 10^17
Expansion & Connectivity
 - 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
 - M.2 2280
- Power Consumption
 - 3 Watt (sequential read) , 3.9 Watt (sequential write)
 - Limited warranty - 5 years
 - 0 °C
 - 70 °C
