Brand
Micron 16GB DDR4 2933 MHz DIMM CL21 Memory
Quicklinx: FT6TWS00 Mfr#: MTA18ASF2G72PDZ-2G9E1
Type: DDR4 SDRAM
Connection: DIMM 288-pin
Speed: 2933MHz
Data Integrity: ECC
Registered/Buffered: Registered with parity
£46.06 ex VAT
£55.27 inc VAT
Marketing description is not available.
Micron - DDR4 - module - 16 GB - DIMM 288-pin - 2933 MHz / PC4-23400 - registered with parity
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2933 MHz (PC4-23400)
Latency Timings
CL21 (21-21-21)
Dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, Low-power auto self refresh (LPASR), registered with parity
Voltage
1.2 V
Lead Plating
Gold
16 GB
Upgrade Type
Generic
133 mm
3.9 mm
31.3 mm
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL21 (21-21-21)
ECC
Module Configuration
2048 x 72
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RoHS, halogen-free
Type: DDR4 SDRAM
Speed: 2933MHz
Data Integrity: ECC
CAS Latency: CL21
Standard: PC4-23400
Brand: Micron
