Micron 16GB DDR4 2666 MHz DIMM CL19 Memory
Quicklinx: G10YWS00 Mfr#: MTA18ASF2G72AZ-2G6E2
Type: DDR4 SDRAM
Connection: DIMM 288-pin
Speed: 2666MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
£73.10 ex VAT
£87.72 inc VAT
Marketing description is not available.
Micron - DDR4 - module - 16 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19 (19-19-19)
Temperature monitoring, dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, Low-power auto self refresh (LPASR), unbuffered
Voltage
1.2 V
Lead Plating
Gold
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL19 (19-19-19)
Access Time
0.75 ns
ECC
Module Configuration
2048 x 72
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RoHS, halogen-free
Type: DDR4 SDRAM
Speed: 2666MHz
Data Integrity: ECC
CAS Latency: CL19
Standard: PC4-21300
Brand: Micron
