Incorporating the latest Bluetooth® wireless technology, this headset lets you connect to your mobile phone or media player without cables. Using A2DP profile, it lets you listen to stereo music by connecting to any Bluetooth®wireless technnology enabled products.
Designed with beautiful finishes, this headset system is ideal for your personal entertainment. Ideal for digital moview, TV, PC/notebook, CD/DVD and multimedia application.
With its built-in microphone, this system functions as an headset for your video conferencing and communication application.
Comes with rechargeable battery for longer lasting use, and easy charging via USB interface. Includes additional 3.5 mm stereo jack for traditional analog audio input.
Features:
- Bluetooth® wireless music transfer lets you play from your mobile and any Bluetooth® product with Bluetooth® headset protocol
- Bluetooth® 4.0 with HFP 1.6 A2DP 1.2 and AVRCP 1.4
- Bluetooth® stereo audio using A2DP for wireless music streaming
- Quality headset with depth and full range audio performance
- CD sound quality with aptX function
- Clear sound with strong bass
- USB charge and play function
- 10 m wireless operating radius
- Built-in noise reduction function
- Microphone/answering phone call
- 3.5 mm stereo jack
- Quality ear-cups for comfortable wear
Technical Specifications
Amplifier specs
Frequency response: 60-20 000, Hz
Signal/Noise ratio: 85, dB
Speakers specs
Material: plastic
Interfaces: Input micro-USB, 3.5 mm stereo jack
Others: Bluetooth®
Version: Bluetooth® V4.0
Profile: HFP 1.6, A2DP 1.2
RF Range: 10 m
Sound: aptX
Playback time: 10 hours
Charging time: 2 hours (6 hour for initial charge)
Standby time: 30 days
- Microlab T1 - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- TV, portable electronics, computer
- Headphones Form Factor
- Full size
- Foldable
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Headphones Technology
- Dynamic
- Bluetooth Version
- Bluetooth 4.0
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 60 - 20000 Hz
- Impedance
- 42 Ohm
- Signal-To-Noise Ratio
- 85 dB
- Microphone
- Built-in
- Controls
- Volume, answer/end, play/pause
- Product Type
- 18 cm
- 18 cm
- Body Material
- Plastic
- Earpad Material
- Soft leather
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Full size
- Headphones Cup Type
- Closed
- Foldable
- Dynamic
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 4.0
- Bluetooth Profiles
- Hands-Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
- Sound Output Mode
- Stereo
- 60 - 20000 Hz
- 85 dB
- Total Harmonic Distortion (THD)
- 1%
- Impedance
- 42 Ohm
- Diaphragm
- 50 mm
Remote Control
- Controls
Wireless Link
- Transmission Range
- 10 m
- Connector Type
- Headset (mini-phone stereo 3.5 mm) , USB (5 pin Micro-USB Type B)
- Cable Details
- USB charge cable , Headset cable
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 10 hour(s)
- Standby Time
- 720 hours
- Recharge Time
- 2 hour(s)
