Microlab Solo 1C 60 Watt 2.0 Speaker System - Wood Finish
Quicklinx: 84N5WS00 Mfr#: MICROLABSOLO1C
Special heritage range for Microlab's 2.0 system that employs high quality design techniques and speaker technology - perfect sound quality and near linear response. It incorporates IGBT OCL circuit for pure tones and dynamic acoustic production. It features high quality sound and full range spectrum and is ideal for all music lovers and audiophiles.
Beautiful wooden cabinets with excellence sound quality
Crystal clear dynamic highs, balanced mid range and deep bass.
Reference monitor quality, driven by high quality drivers.
Each cabinet with 1" tweeter for high notes and woofer for mid to low depths and bass.
Ideal for music, movies and digital media playbacks
Technical Specifications
Amplifier specs
Output power: 60, Watt RMS
Power distribution: 30x2, Watt
Harmonic distortion: 0,3, % (1Watt, 1kHz)
Frequency response: 64-20 000, Hz
Signal/Noise ratio: 75, dB
Separation: 50, dB
Speakers specs
Tweeter driver: type 1,
Bass driver type: 5,
Material: MDF
Color: dark wood
Remote control: 1
Output: terminals
Input: 2RCA
Dimensions
Satellites: 183 x 300 x 212, mm
Product Net weight: 10,40, kg
Microlab SOLO-1C - speakers - for PC
Speakers - for PC
System Components
2 speakers
Speaker Type
2-way - active
Continuous Power
30 Watt
Frequency Response
64 - 20000 Hz
Amplifier
Integrated
Speaker System Details
2 30 Watt - 64 - 20000 Hz
AC 230V (50 Hz)
18.3 cm x 21.2 cm x 30 cm
Speakers - for PC
Enclosure Material
Wood
Speaker System
System Components
2 speakers
Speaker Type
2-way - active
Continuous Power
30 Watt
Frequency Response
64 - 20000 Hz
Signal-To-Noise Ratio
75 dB
Amplifier
Integrated
Speakers Included
2 - 2-way - 30 Watt - 64 - 20000 Hz - wired
Driver Details
Woofer driver - 5" , Tweeter driver - 1"
Connector Type
Audio line-in (RCA x 2)
Audio cable, remote control
Remote Control
Remote control - infrared
Power supply
Power Source
AC power adapter
AC 230V (50 Hz)
18.3 cm
21.2 cm
30 cm
