Microlab MD220 - Portable speaker - 2 Watt
Quicklinx: 8F2HWS00 Mfr#: MICROLABMD220
Portable stereo speakers for tablets and notebooks.
Enhance and power your tablet music and sound.
Compact design and small soundbar system with two quality speaker drivers. Broaden your tablet sound range and listen to distinct sound effects.
Easy connection with 3.5mm stereo plug and mount your tablet in front for quick setup. Comes with rechargeable battery for portability. Travel with your tablet and enjoy to enhanced sound everywhere you go.
Watch movies and listen to music while on-the-move.
-Quality stereo speaker system with built-in amplifier
-Ideal for movies, gaming, music and pc applications
-Clear and uncoloured sound
-Soundbar type design
-Connects to any 3.5mm stereo jack easily e.g., tablet, PC, notebook, Mp3/Mp4, CD/DVD player, etc.
-Rechargeable battery with easy replacement
-Two power modes: USB or Lithium battery powered
-3.5 mm stereo plug and wire connected to speaker; no separate cable required.
Technical Specifications
Amplifier specs
Output power 2, Watt RMS
Power distribution 1x2, Watt
Harmonic distortion 0,5, % (1Watt, 1kHz)
Frequency response 150-20 000, Hz
Signal/Noise ratio 75, dB
Separation 40, dB
Speakers specs
Tweeter driver type 1,5,
Tweeter rated power 2, Watt
Material piastic
Input 3,5 mm stereo
Dimensions
Satellites 195x59.5x57, mm
Product Net weight 0,44, kg
Microlab MD220 - speaker - for portable use
Speaker - for portable use
Speaker Type
Active
Continuous Power
2 Watt
Frequency Response
150 - 20000 Hz
Amplifier
Integrated
Speaker Details
Speaker - stereo x 2 - 1 Watt - 150 - 20000 Hz - 4 Ohm - active
Image Colour Disclaimer
The displayed product image may be a different colour
Power Options
USB charging, USB powered
Speaker battery rechargeable - Lithium Ion
19.5 cm x 5.7 cm x 5.95 cm
350 g
Speaker System
Speaker Type
Active
Continuous Power
2 Watt
Frequency Response
150 - 20000 Hz
Signal-To-Noise Ratio
75 dB
Total Harmonic Distortion
0.5%
Amplifier
Integrated
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 1 Watt - 150 - 20000 Hz CFR - 4 Ohm - active
Driver Details
Speaker: full-range driver - 1.5"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm) , DC power input
Audio cable, USB charge cable
Power Source
Options
Rechargeable - Lithium Ion
19.5 cm
5.7 cm
5.95 cm
350 g
