Microlab M223U is a multiple-function speaker for your desktop audio. It is simple to operate and good for listening music. Plug in this system and boost your desktop music entertainment instantly.
Beautiful Looking Design
M223U applies a modern desgin concept for its cabinets. All the satellites and subwoofer are maden by using hi-end wooden materials.
Good sound performance
M223U has excellent audio qualtiy.The subwoofer is built in the bass reflex technology and the satellites give clean treble sound.
Built-in Useful functions
M223U is the perfect companion for expanding your desktop entertainment. It does not only integrate the music playing function, but also can read SD card and listening radio programmes. It also support USB flash disk reading.
Convenient operation system
M223U is easy to use. The front panel on the subwoofer cabinet houses the playback and master volume controls.. It is also very easy to connect with most media players through the standard audio cable.
Features:
- Quality 2.1 subwoofer system with depth and full range audio performances
- Powerful subwoofer and crystal clear satellites
- Front panel with playback controls and volume level knob
- Bass reflex design for efficient subwoofer performances
- Made with quality sound handling materials for superb sound handling characteristics
- Analog FM radio with telescopic antenna
- USB type A and SD card slots for digital music playbacks
- Microlab M-223U - speaker system
- Product Type
- Speaker system - 2.1-channel
- Media Content Source
- USB-host, flash memory card
- FM radio
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 17 Watt
- Frequency Response
- 35 - 20000 Hz
- Amplifier
- Integrated
- Audio Formats
- WMA, MP3
- Speaker System Details
- 1 x subwoofer 9 Watt 8 Ohm , 2 x satellite speaker 4 Watt 4 Ohm
- Black
- 3.2 kg
- 1-year warranty
- Product Type
- FM radio
- Enclosure Colour
- Black
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 17 Watt
- 35 - 20000 Hz
- Signal-To-Noise Ratio
- 75 dB
- Total Harmonic Distortion
- 0.1%
- Amplifier
- Integrated
- Audio Formats
- WMA, MP3
- Speakers Included
- 1 x subwoofer - 9 Watt - 8 Ohm - wired , 2 x satellite speaker - 4 Watt - 4 Ohm - wired
- Driver Details
- Subwoofer: subwoofer driver - 4"
- Driver Details (2nd speaker)
- Satellite speaker: full-range driver - 2.5"
- Connector Type
- Audio line-in (RCA x 2)
- Included Accessories
- 3.5 mm to RCAx2 cable
- Power Source
- AC power adapter
- 3.2 kg
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 8.9 cm x 9.7 cm x 15.2 cm , Subwoofer: 15.5 cm x 28.5 cm x 24.2 cm
- Limited warranty - 1 year
