Microlab M200 Platinum 2.1 Stereo Speaker System - 40W RMS
Quicklinx: 93B8WS00 Mfr#: MICROLABM200
A beautifully designed 2.1 subwoofer speaker system with a stunning black finishe. Ideal for use with digital multimedia and computer systems. Experience a full range of audio and deeper bass within the wooden subwoofer cabinet. The satellite speakers are in stands for perfect optimum listening position.
Designed by Microlab's Danish chief consultant, Peter Larsen - speaker design with perfect acoustic production.
Features:
  • Powerful 2.1 subwoofer system with full range acoustic performances in depth and resolution.
  • Ideal for digital multimedia and computer applications
  • Unique designed 5" subwoofer for deep bass and strong vocal clarity
  • Wired remote volume control with 3.5mm stereo jack for direct input and output to headphones
  • Magnetically shielded for interference free positioning
Technical Specifications:
Amplifier
Output power: 40 Watt RMS
Power distribution: 12 Watt x 2 + 16 Watt
Harmonic distortion: < 0.3% 1W 1kHz
Frequency response: 35Hz - 20kHz
Signal/Noise ratio: > 80dB
Separation: > 45dB
Input sensitivity: 400mV
Nominal impedance: 6 ohm
Speakers:
Tweeter driver type: 2.5"
Tweeter rated power: 10 Watt
Bass driver type: 5"
Bass rated power: 15 Watt
Frequency range: 35Hz - 20kHz
Interfaces:
Output: 2RCA sockets
Input: 2RCA sockets
Microlab M-200 - speaker system - for PC
Speaker system - for PC - 2.1-channel
System Components
2 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
40 Watt
Frequency Response
40 - 20000 Hz
Amplifier
Integrated
Speaker System Details
1 x subwoofer , 2 x satellite speaker
Speaker System
System Components
Speaker Type
Active
Audio System Continuous Power (Total)
40 Watt
Frequency Response
40 - 20000 Hz
Signal-To-Noise Ratio
80 dB
Amplifier
Integrated
Speakers Included
1 x subwoofer - wired , 2 x satellite speaker - wired
Driver Details
Subwoofer: subwoofer driver - 5"
Driver Details (2nd speaker)
Satellite speaker: full-range driver - 2.5"
Power Source
AC power adapter
Dimensions (WxDxH) / Weight Details
Satellite speaker: 9 cm x 17 cm x 9 cm , Subwoofer: 27 cm x 18.9 cm x 15.6 cm
