Microlab H21 Wireless Bluetooth Speakers
Quicklinx: 81ZFWS00 Mfr#: MICROLAB-H21 Black
Incorporating Bluetooth technology for wireless music entertainment. This system lets you connect to your mobile phone or media player without cables. Using A2DP or AVRCP profiles, it lets you listen to stereo music by connecting to any Bluetooth enabled device.
Designed with beautiful leather finishes, this versatile stereo system fits perfectly in your living room, computer room or even your bedroom. Bass reflex tunnel design means deeper bass effects. Classic bookshelf stereo speaker arrangement creates better dynamic sound movements for realistic effects.
Ideal for digital movies, TV. PC / notebooks, CD / DVD and multimedia application.
Comes with two audio methods, wireless Bluetooth music transfer and traditional audio connection.
Technical Specifications
Amplifier specs
Output power - 36, Watt RMS
Power distribution - 18x2, Watt
Harmonic distortion - 0,3, % (1Watt, 1kHz)
Frequency response - 50-20 000, Hz
Signal/Noise ratio - 70, dB
Separation - 60, dB
Speakers specs
Tweeter driver type - 1
Bass driver type - 3.5
Material - MDF
Output - terminals
Input - 2RCA
Auxilliary - Bluetooth
Dimensions
Satellites - 116x198x202 , mm
Product Net weight - 4.7, kg
Microlab H21 - speakers - wireless
Speakers
System Components
2 speakers
Enclosure Design
Bass reflex
Speaker Type
2-way - active
Nominal Output Power (Total)
36 Watt
Frequency Response
50 - 20000 Hz
Amplifier
Integrated
Bluetooth
Speaker System Details
2 18 Watt - 50 - 20000 Hz
Image Colour Disclaimer
The displayed product image may be a different colour
4.7 kg
1-year warranty
Speakers
Enclosure Design
Bass reflex
Enclosure Material
Wood
Design Features
Leather finish
Speaker System
System Components
2 speakers
Speaker Type
2-way - active
Audio System Continuous Power (Total)
36 Watt
Frequency Response
50 - 20000 Hz
Signal-To-Noise Ratio
70 dB
Total Harmonic Distortion
0.5%
Amplifier
Integrated
Bluetooth 2.1 EDR
Recommended Placing
Bookshelf
Controls
Volume
Interface Type
Bluetooth
Additional Features
Charging
Speakers Included
2 - 2-way - 18 Watt - 50 - 20000 Hz - bookshelf - wired
Driver Details
Woofer driver - 3.5" , Tweeter driver - 1"
Connector Type
Audio line-in (RCA x 2) , DC power input , DC power output (4 pin USB Type A (power only))
Audio cable, power adapter, speaker cable
Power adapter - external
4.7 kg
Dimensions (WxDxH) / Weight Details
Right channel speaker: 11.6 cm x 20.2 cm x 19.8 cm , Left channel speaker: 11.6 cm x 20.2 cm x 18.9 cm
Limited warranty - 1 year
