Uniquely designed 2.1 speaker system in a single compact sound box. Aesthetic in design, it fits into most room types such as bedroom, kitchen or even your studies.
Connects wirelessly to your Bluetooth wirelessly technology enabled mobile phone or media player. Enjoy music without any messy cables from the music source. Listen to your favorite music from your mobile phone, tablet, or notebook. Alternatively you can connect to traditional 3.5 mm stereo music source.
Highly portable, this system features rechargeable battery and hand grip that lets you use it almost anywhere.
2.1 speaker system for full range music production
Wireless music with Bluetooth® technology
Generous bass effects and clear treble
Front panel controls for playback and Bluetooth® pairing functions
Comes with alternative 3.5mm stereo connection to most media players and computer
Rechargeable battery powered for portable use; carry it with you -True wireless, no cable needed for audio playback;
- CSR latest lossless transmission Bluetooth chipset to ensure a lossless transmission;
- Stylish design available in 3 iPod colors;
- Built-in rechargeable battery make sure that you can take it anywhere you want
- Built-in 2.1 powerful amplifier and US TI DSP technology to ensure an awesome audio performance
- Microlab MD312 - speaker - for portable use - wireless
- Product Type
- Speaker - for portable use - 2.1-channel
- Speaker Type
- Active
- Nominal Output Power (Total)
- 9 Watt
- Frequency Response
- 40 - 18000 Hz
- Bluetooth
- Speaker Details
- Speaker - stereo x 2 - 4 Watt - 4 Ohm , Speaker - subwoofer - 5 Watt - 2 Ohm
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Battery
- Speaker battery rechargeable - lithium
- 17.5 cm x 10.9 cm x 17.8 cm
- 1 kg
- Product Type
Speaker System
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 9 Watt
- 40 - 18000 Hz
- Signal-To-Noise Ratio
- 65 dB
- Total Harmonic Distortion
- 5%
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Advanced Audio Distribution Profile (A2DP)
Speaker System Details
- Speaker Details
- Driver Details
- 2 x tweeter driver - 2" , Woofer driver - 3"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, power adapter
- Power Source
- Battery
- Rechargeable - lithium
- 17.5 cm
- 10.9 cm
- 17.8 cm
- 1 kg
