Meta Quest 3S Compact Charging Dock
Quicklinx: HVP8WS00 Mfr#: SK-1000009-01
33 left in stock
£29.17 ex VAT
£35.00 inc VAT
Express delivery Delivered on Tuesday
Stay powered and ready to play in mixed reality and VR with this compact charger, featuring drop-in wireless controller charging.
Keep your Meta Quest 3/3S headset and Touch Plus controllers organised while they charge back up. Includes an extended headset charging cable and rechargeable lithium-ion batteries for your controllers. This charging dock works while using Active Straps without the need to remove them (sold separately)
  • Compact design
    The compact design of the charging dock allows it to fit seamlessly into any gaming setup without taking up excessive space.
  • Efficient charging
    With a power output of 27 W and compatibility with multiple voltage levels, the dock ensures efficient charging for your controller.
  • Versatile connectivity
    Equipped with a USB-C cable and input connectors, it offers versatile connectivity options for charging.
  • Integrated battery
    The included lithium-ion battery enhances the charging dock's utility, allowing for reliable power when needed.
  • LED indication
    The charging LED indication provides clear visibility of the charging status, making it easy to know when the controller is ready to use.
Meta charging dock - compact - with battery - 2 - Li-Ion - 24 pin USB-C - 27 Watt
Charging dock + battery
14 cm x 14.4 cm x 7.4 cm
480 g
Moonstone white
Output Connector Type
24 pin USB-C
9 / 12 / 15 V
Voltage Provided
5 / 9 / 12 V
Wireless Charging
Lithium Ion - 167 mAh - 0.64 Wh
Power Provided
27 Watt
Power Device Details
- 24 pin USB-C , 2 x - wireless charging stand - 2 W
Cables
USB-C cable - 1.8 m
Batteries Included
2 pcs.
Meta Quest 3, Quest 3S
Charging dock battery
Virtual reality headset controller
14 cm
14.4 cm
7.4 cm
480 g
Enclosure Colour
Moonstone white
9 / 12 / 15 V
Input Connectors
24 pin USB-C
Input Connectors Qty
1
Voltage Provided
5 / 9 / 12 V
Output connectors
24 pin USB-C
Power Provided
27 Watt
24 pin USB-C , 2 x wireless charging stand - 2 W
Wireless Charging
Charging LED indication
Compatible Game Consoles
Meta Quest 3
Lithium Ion
Included Qty
2
Voltage Provided
3.85 V
167 mAh - 0.64 Wh
USB-C cable - 1.8 m
