Meta Quest 3S compact carry case
Quicklinx: HVPCWS00 Mfr#: SK-1000044-01
Enjoy your Meta Quest on the go with a hard protective case that takes up less space in your bag, so you can experience VR and mixed reality anywhere. The thoughtful design features an outer felt shell, soft hand strap and contoured inner compartments to keep your gear organised and secure. It’s designed to fit your Quest 3/3S, two Touch Plus controllers with lanyards or Active Straps, a charging cable and adapter. With its lightweight construction, zip opening and rounded profile, this premium Meta accessory makes it easier than ever to access your Meta Quest 3/3S and accessories wherever you are.
  • Durable construction
    The carrying case is built using high-quality materials such as polyester and polycarbonate, ensuring it withstands the rigors of transportation and everyday use.
  • Organized storage
    Equipped with multiple compartments, this case allows for efficient storage of the virtual reality headset, cables, power adapters, and controllers, simplifying the packing and unpacking process.
  • Soft lining
    A microfiber lining is integrated into the design to protect the headset from scratches and damage, ensuring it remains in pristine condition while in storage.
  • Secure closure
    The zipper closure mechanism provides a reliable way to keep the case shut, protecting the contents from dust and impact.
  • Compact and portable
    The overall design of the Compact carrying case emphasizes portability, making it easy to transport the virtual reality headset and accessories wherever needed.
Meta Compact - hard case for virtual reality headset
Hard case for virtual reality headset
22.3 cm x 26.3 cm x 11.5 cm
456 g
Material
Recycled felt, thermoplastic polyurethane (TPU), polycarbonate, polyester, spandex
Light grey, slate black
Meta Quest 3S; Quest 3
22.3 cm
26.3 cm
11.5 cm
456 g
Material
Lining Material
Microfibre
Carrying Case
Hard case
Recommended Use
For virtual reality headset
Closure Type
Zipper
Additional Compartments
Cable, power adapter, 2 x controllers
Meta Quest 3S , Meta Quest 3
