Meta Quest 3S Carry Case
Quicklinx: HVPDWS00 Mfr#: SK-1000045-01
More than 50 In Stock
£20.84 ex VAT
£25.00 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
Take your headset and accessories on the go with style and protection. This case is designed to fit your headset, Touch Plus controllers, charging cable, adapter, head strap (standard or Elite) and Active Straps. The exterior shell features custom durable felt, and the inner compartments keep your gear organised and secure. With its lightweight construction, soft hand strap, zip opening and rounded profile, the case makes it easy to carry and access your Meta Quest 3/3S and accessories on the go. This premium Meta accessory ensures a perfect fit, durability and convenience for your mixed reality and VR setup.
  • Durable design
    The hard case is designed to withstand the rigors of transport while keeping the virtual reality headset and its accessories safe from damage.
  • Eco-friendly material
    Constructed from recycled felt, this case demonstrates a commitment to sustainability without compromising on functionality.
  • Ample storage space
    With separate compartments, users can easily store and access the cable, power adapter, and two controllers, ensuring everything is organized.
  • Secure closure
    The zipper closure provides reliability, ensuring that all contents stay secure and preventing accidental spills during movement.
Meta - hard case for virtual reality headset
Hard case for virtual reality headset
24.2 cm x 32.8 cm x 12.8 cm
674 g
Material
Recycled felt
Light grey, slate black
Meta Quest 3, Quest 3 (128 GB), Quest 3 (512 GB), Quest 3S, Quest 3S (128 GB), Quest 3S (256 GB)
24.2 cm
32.8 cm
12.8 cm
674 g
Material
Recycled felt
Carrying Case
Hard case
Recommended Use
For virtual reality headset
Closure Type
Zipper
Additional Compartments
Cable, power adapter, 2 x controllers
