Meta Quest 3S Breathable Facial Interface
Quicklinx: HVP9WS00 Mfr#: SK-1000039-01
34 In Stock
£24.99 ex VAT
£29.98 inc VAT
Express delivery Delivered on Wednesday
Get more into your favourite experiences with a facial interface that increases ventilation while you move. The design distributes weight for a comfortable fit during active mixed reality and VR sessions. When you’re done playing, you can easily wipe sweat off the silicone, whether you’re in a solo session or sharing your headset with others. This premium Meta accessory installs in seconds, allowing you to get a more comfortable experience each time you use your Meta Quest 3S.
  • Comfortable and breathable design
    The face interface is engineered to provide a breathable experience, making it suitable for long gaming or immersive VR sessions. This thoughtful design helps to keep the user cool and comfortable throughout usage.
  • Durable material composition
    Crafted using a blend of plastic, fabric, and silicone, this headset accessory is built to withstand regular use while maintaining a lightweight feel. The materials ensure a snug fit.
  • Easy to maintain
    With its washable feature, the face interface can be cleaned, allowing for hassle-free maintenance. This ensures that users can keep the accessory fresh and hygienic for repeated use.
Meta virtual reality headset face interface - breathable
Virtual reality headset face interface
Light grey
Product Material
Plastic, fabric, silicone
10.6 cm x 16.6 cm x 10.4 cm
62 g
Meta Quest 3S
Product Material
10.6 cm - 16.6 cm - 10.4 cm
62 g
Light grey
Washable
Meta Quest 3S
