Discover the magic of Meta Quest 3S.
When you blend digital games, workouts and entertainment into your physical space, you can experience everything you love in a new way.
Turn any room into an immersive cinema. Step right into the action of your favourite games. Hang out with friends from anywhere but feel like you’re in the same place.
Quest 3S is wireless and light, so you can move with total freedom.
Unreal experiences at an unreal price.
See child safety guidance online; accounts for 10+.
High-resolution display
With a resolution of 1832 x 1920 per eye, this VR headset ensures that every detail is rendered clearly, providing an engaging and lifelike experience. -
Comfortable fit
The adjustable headband allows users to customize the fit for maximum comfort, making it ideal for long gaming sessions or extended virtual experiences. -
Powerful processing capabilities
Powered by the Qualcomm Snapdragon XR2 Gen 2 and equipped with 8 GB of RAM, the Quest 3S delivers smooth performance and quick responsiveness, ideal for dynamic content. -
Effective tracking technology
Equipped with two RGB cameras, this headset ensures reliable tracking, enhancing the user’s ability to interact with the virtual environment seamlessly. -
Long-lasting battery life
Featuring a robust 4324 mAh battery, the Quest 3S offers extended hours of playtime, allowing users to dive deep into their virtual adventures without frequent interruptions.
Meta Quest 2 Link Cable | In Stock | £70.83 |
