Keep your Meta Quest 3 headset clean and comfortable with this soft, silicone facial interface. Its soft, flexible materials are designed to provide skin comfort and a perfect fit, even during the most intense workouts or gaming sessions. Easily wipe off sweat and dirt while also blocking unwanted light from entering your headset. This genuine Meta Quest accessory installs in seconds and can even be used with glasses. Enjoy a cleaner, more comfortable experience each time you use your Meta Quest 3, whether you use it for yourself or share your headset with others.
Comfortable silicone material
The face cushion is crafted from silicone, providing a soft touch that is gentle on the skin, making it suitable for long hours of immersive virtual reality experiences. -
Hygienic design
The silicone material is easy to clean, ensuring that the face cushion remains hygienic for multiple users and is safe for regular wear.
- Meta virtual reality headset face cushion - silicone
- Product Type
- Virtual reality headset face cushion
- Black
- Product Material
- Silicone
- 10.5 cm 9.4 cm
- Length
- 16.7 cm
- 80 g
- 1-year warranty
- Product Type
- Product Material
- Silicone
- 10.5 cm 9.4 cm
- Length
- 16.7 cm
- 80 g
- Black
- Limited warranty - 1 year
