Meta Quest 3 Elite Strap with Battery
Quicklinx: HDVTWS00 Mfr#: 899-00560-01
Type: Strap
£108.33 ex VAT
£129.99 inc VAT
Play in comfort and get up to two hours additional VR game playtime with this adjustable ergonomic head strap that features a built-in, lithium-ion battery pack. Charge your Meta Quest 3 and head strap battery simultaneously with a single charging cable. The strap easily adjusts to fit most head sizes with the easy-to-use dial while distributing headset weight for a more comfortable fit. This genuine Meta Quest accessory also reduces fatigue with a soft, flexible silicone support that cradles the back of your head and adds stability.
Ready for anything
This compact, lightweight strap reduces facial pressure and evenly distributes weight for a more comfortable fit. It also has improved durability, building on the learnings from our earlier generations of Elite Strap.
Keep the fun going
Get up to two hours additional VR game playtime with the built-in battery pack. Charge your headset and head strap battery simultaneously using a single charging cable.
Adjusts in seconds
A twist of the adjustment dial gives you a snug, precise fit around your head, so you can move confidently whether you're battling it out or getting your sweat on.
Longer immersion
A soft, flexible silicone support cradles the back of your head for the most comfortable and balanced fit for any experience.
Seamless compatibility
Works with the Meta Quest 3 Charging Dock for effortless headset and controller charging. Also fits in the Meta Quest 3 Carrying Case without having to be removed.
Genuine Meta Quest accessory
Built to work seamlessly with Meta Quest 3 and backed by a one year warranty, this official accessory has been tested for quality and durability – ensuring you get the best look, feel, compatibility and performance.
  • Comfortable
    Enhanced stability and ergonomics allow for more comfort.
  • Personalized fit
    With improved fine tuning for better adjustment.
  • Distributed weight
    Allows for longer, more comfortable time in MR.
  • Extended battery capacity
    The built-in rechargeable battery enhances the time for uninterrupted usage.
  • Charging indication
    LED light indicates charging levels.
Meta Elite - VR headband for virtual reality headset
VR headband
Intended For
Virtual reality headset
Rechargeable
Run Time (Up To)
2 hour(s)
Package Content
Head strap with battery
Product Material
Plastic, fabric, silicone
17.31 cm x 10.15 cm x 24.1 cm
331 g
White
Meta Quest 3
VR headband
Intended For
Package Content
Product Material
17.31 cm
10.15 cm
24.1 cm
331 g
White
Rechargeable Battery
Rechargeable
2300 mAh
Run Time (Up To)
2 hour(s)
Meta Quest 3
Type: Strap
Brand: Meta
