Meta Quest 3 Elite Strap
Quicklinx: HDVWWS00 Mfr#: 899-00510-01
46 In Stock
£54.17 ex VAT
£65.00 inc VAT
Express delivery Delivered on Tuesday
Play in comfort with this adjustable, ergonomic head strap that fits most head sizes with the quick turn of a dial. This Elite Strap upgrades your fit by taking pressure off your face for increased comfort and weight distribution. The soft, flexible silicone support cradles the back of your head, reducing fatigue. This genuine Meta Quest accessory easily installs on your Meta Quest 3 for a perfect and secure fit every time you play, create and explore in VR.
Ready for action
This compact, lightweight strap reduces facial pressure and evenly distributes weight for a more comfortable fit. It also has improved durability, building on the learnings from our earlier generations of Elite Strap.
Adjusts in seconds
A twist of the adjustment dial gives you a snug, precise fit around your head, so you can move confidently whether you're battling it out or getting your sweat on.
Longer immersion
A soft, flexible silicone support cradles the back of your head for the most comfortable and balanced fit for any experience.
Perfect alignment
This flexible top strap adjusts to keep your headset at a comfortable position over your eyes and further disperses weight.
Seamless compatibility
Works with the Meta Quest 3 Charging Dock for effortless headset and controller charging. Also fits in the Meta Quest 3 Carrying Case without having to be removed.
Genuine Meta Quest accessory
Built to work seamlessly with Meta Quest 3 and backed by a one year warranty, this official accessory has been tested for quality and durability – ensuring you get the best look, feel, compatibility and performance.
  • Enhanced comfort
    Crafted from a blend of fabric, plastic, and silicone, this head strap offers a comfortable fit for extended virtual reality sessions. Its materials are chosen for their durability and flexibility, ensuring a snug yet gentle grip on the head.
  • Easy integration
    Designed specifically for the Meta Quest 3, this head strap seamlessly integrates with your virtual reality headset. It enhances the overall experience by providing a stable and secure fit, allowing for immersive gameplay without distractions.
Meta Quest 3 - head strap for virtual reality headset
Head strap
Intended For
Virtual reality headset
Package Content
Head strap
Product Material
Plastic, silicone, fabric
16.45 cm x 24.02 cm x 10.15 cm
183 g
White
Meta Quest 3
Head strap
Intended For
Package Content
Head strap
Product Material
16.45 cm
24.02 cm
10.15 cm
183 g
White
Meta Quest 3
Type: Controller Strap
Brand: Meta
