Express yourself in Elemental Blue and stay comfortable in Meta Quest 3. The fabric facial interface provides breathable cushioning while blocking out unwanted light. Colour-matched, flexible head straps fully adjust to most head sizes for added support when you play and connect in VR. Also available in Blood Orange.
Enhanced comfort
Designed with a soft fabric material, the face gasket and head strap ensure a comfortable fit, making extended VR sessions more enjoyable. -
Easy customization
The kit allows for quick and easy swapping of the face gasket and head strap, enabling users to find their perfect fit and share the device with others without hassle.
- Meta virtual reality headset face cushion kit
- Product Type
- Virtual reality headset face cushion kit
- Package Content
- Face gasket, head strap
- Elemental blue
- Product Material
- Fabric
- 23.4 cm x 19.3 cm x 17.3 cm
- 121 g
- 1-year warranty
- Designed For
- Meta Quest 3
- Product Type
- Package Content
- Product Material
- Fabric
- 23.4 cm - 19.3 cm - 17.3 cm
- 121 g
- Elemental blue
- Limited warranty - 1 year
- Designed For
- Meta Quest 3
